From clever storage to road-trip essentials, here’s a hand-picked roundup for Tremor owners!
![]() | BuiltRight Industries Rear Seat Release (F-150 2009–2025 / Super Duty 2017–2025) Pull-strap + bracket lets you release the driver-side rear seat latch for quick behind-seat storage access; installs in minutes. |
![]() | DuPont Rubber Saver – Gasket/Seal/Trim Conditioner (25 ml) Conditions and protects door and window seals; helps prevent sticking in freezing temps; rub-on applicator included. |
![]() | PIMCAR Center Console Organizer Tray (F-150 2021–2025 / Lightning) Half-sized ABS tray adds divided storage in the full console (bucket seats only); designed to work with the factory lower tray. |
![]() | FITCAMX 4K Dash Cam (OEM-Style) for Ford F-150 Factory-look integrated camera kit (model Y2124-4K) with 4K front recording, loop recording, G-sensor and Wi-Fi app control. |
![]() | Krytox by Chemours GPL 205 Grease Premium grease and oil for bearings, valves, seals, and other applications over a wide temperature range and under extreme conditions. (Sunroof Seal) |
![]() | B&W Trailer Hitches Tow & Stow Adjustable Trailer Hitch Ball Mount Adjustable ball mount with stainless pins allows quick height changes for level towing; stows under bumper when not in use. |
![]() | Ruff Liners Large Back-Seat & Door Protector (Truck-Size) Water-resistant rear-seat cover with door guards sized for full-size trucks; protects upholstery from mud, fur, and claws. |
![]() | CURT 45936 Deep-Drop Adjustable Hitch Ball Mount (Dual-Ball, 2" Shank) Up to 10" drop / 9" rise for precise trailer leveling; 2" & 2-5/16" balls; up to 15,000-lb capacity depending on ball. |
![]() | iCrimp AP-11 Crimping Tool for 15/30/45A Powerpole Contacts Ratcheting crimper with built-in positioner for Anderson-style 15A, 30A, and 45A contacts (10–20 AWG). |
![]() | WOLFBOX 12V Dual-Zone Car Refrigerator (40-Quart) Portable fridge/freezer (-8°F to 68°F) with app control; runs on 12/24V DC or 100/240V AC for truck, RV, or home use. |
Which of these upgrades would you add to your F-150 Tremor first? Let us know below!
