1.5” Wheel Spacers
Anyone running 295/70R18 with a 2.5” leveling kit and 1.5” wheel spacers? Wondering if it would need trimming due to the wheel spacers?
I’m running 35/12.50 with auto spring offset 2.5 leveling kit and 1.5 wheel spacers. I had to do considerable trimming of both front and rear crashbars and fender plastic trim and I still have rubbing only if I take a hard turn while accelerating and compressing the shock at the same time like entering a plaza, driveway etc. the other 99% no rubbing and rides awesome.
You would definitely need to do trimming if you add the 1.5 spacer. A 1 inch space you’d probably be ok like my 99% ex above. If you don’t use a Wheel spacer you’ll be fine 100% but you’ll be sad because the poke looks so much better.
See before and after adding the 1.5 wheel spacer. 2.5 lift and 35’s already installed in all pics.
That looks awesome man I would love to have that stance but I’ll probably just going to go with a 1” spacer. I’ve been looking but I can’t seem to find any just 1.25” do you know any sites that sell the 1”?
Ever find any 1in spacers?
1” require trimming of factory studs I would recommend smaller or 1.5”.
Even with the pockets in the stock wheel?
