- Dec 20, 2020
- 1,370
- 1,775
- Austin, TX
- '25 F250 Diesel Tremor
- Current Ride #2
- '21 Ford Bronco
Ben Hardy compares the 401A F150 Tremor to a 402A F150 Tremor.
4-auto was my driving force too. Love it. If 401a had it, done deal.400A, 401A, and 402A Window Stickers — I like having 4 Auto as an option, so 402A for me.
400A
401A
402A
The rear axle is equipped with a locking differential (Ford says a Torsen front limited-slip differential will be available later), and its four-wheel-drive transfer case is borrowed from the F-150 Raptor.
I didn't realize that. I thought they all did. The Raptor transfer case also provides mechanically locking 4WD where the normal F150 transfer case uses clutch systems for 4WD.I believe the “4A” is due to the Raptor transfer case — packages 400A and 401A do not have the Raptor Transfer Case:
2021 Ford F-150 Tremor Has Raptor's Transfer Case, Costs $51,200
Tremors have an upgraded suspension and are powered by a 400-hp 3.5-liter EcoBoost V-6. They will arrive this summer.www.caranddriver.com
Here is some background on the development of the Raptor transfer case:
Ford Raptor unique front driveline
Ford Raptor unique front driveline BorgWarner Torsen Mark Lecronewww.sae.org
Unique transfer case
The Raptor’s transfer case features both a TOD, clutch-based system to dynamically apportion power to the front axle for pavement-based scenarios, as well as a dog-clutch-type setup to mechanically connect the front and rear drivelines for low-traction, off-road duty. According to Pritish Khale of BorgWarner’s Program Engineering, the transfer case was developed for the Raptor after the OEM requested a “mechanical lock/torque-on-demand transfer case.” BorgWarner’s PowerDrive Systems Team worked with Ford over a three-year span (2014-16) for the transfer case’s launch on the 2017 Raptor.
According to Khale, the biggest challenge was packaging the two typically separate systems in a single case. “Due to the mechanical lock, it’s an ‘active’ transfer case that can also act as a ‘part-time’ transfer case,” he said. Beyond packaging, there was the goal of maximizing component commonality to keep the bill-of-material and manufacturing costs down. “Also,” Khale added, “it goes in a truck which is known for its off-roading abilities.”
To shift from the clutch-based TOD mode (“4Auto”) to a mechanically locked mode (“4Hi”; “4Lo”), a servo motor rotates a shift cam, which moves a mode fork that drives a locking collar rearward via a locking hub. “The locking collar engages with the upper drive sprocket and transfers torque to the lower-driven sprocket through a chain,” Khale explained. “The lower sprocket is splined to the front output shaft, and as a result the torque is split between front and rear shafts.”
Haha...maybe they just removed the switch.My logic is based on the 4A option — if the truck has the Raptor transfer case, you have 4A — I don’t believe packages 400A and 401A have 4A mode.
I could be wrong… maybe there is Raptor transfer case lite — no 4A. LOL
Read the SAE article I linked above — it dives deep into the the design of the Raptor transfer case. See you on the other side.Haha...maybe they just removed the switch.
Oh I've read that one before. And you are right, the "Hi-Lock" transfer case only gets added on the 402A. I just went through the build site again. I'm surprised by that. According to a forum I was reading months ago, it's only like $100 part difference. Some of the guys are putting them in their Lariats.Read the SAE article I linked above — it dives deep into the the design of the Raptor transfer case. See you on the other side.
Here is its again for ease:
It's definitely helped me out. Without the Torsen diff and deflating my tires, I'm not sure I would have made it out of a trail I got on by mistake last hunting trip. There was no backing out and no space to turn around. It was a road that turned into a SxS trail. My brother had to walk as my guide and had my mirrors folded in too. Muddy and boulders.I am going to be adding the front Torsen LSD to my truck — unfortunately that $500 build upgrade will cost me a little bit more to add.
I am also day dreaming of some new turbos, intercooler, radiator, and tune for ~700HP — I should stop and wait… Raptor in 3-5 years. LOLIt's definitely helped me out. Without the Torsen diff and deflating my tires, I'm not sure I would have made it out of a trail I got on by mistake last hunting trip. There was no backing out and no space to turn around. It was a road that turned into a SxS trail. My brother had to walk as my guide and had my mirrors folded in too. Muddy and boulders.
| Front-Axle w/Torsen® Differential | 61T | O | O | O |
As far as I know, you have to get the 402A in order to get 4Auto. I don't see in on my sticker either, but if you go back to the video, (time=7:10) you can see the 401A doesn't have 4A and (time= 9:58) the 402A does have 4A.I must be blind, where does it state 4 auto on the window sticker? My window sticker is a bit different.
Besides 4A the most important thing the Hi-Lock transfer case provides is mechanical locking of 4H and 4L. The transfer cases in the Lariats with 4A don't have that feature and use a clutch system.Thought I’d add this link to a thread regarding the unique 4A transfer case that is only available with the 402A and the Raptor. Hope this helps.
https://www.f150tremor.com/threads/torque-on-demand®-tod-transfer-case-402a-only.276/
