2024 Tremor Bumper
Who is going to try putting a 2024 Bumper on our 2021-2023s first? Can’t wait to see the result and how easy/difficult.
I think you should go for it first.
I'd like to see if they fit. I might be game for the rear bumper upgrade.
think we're all kinda chompin at the bit for someone somewhere to try a modular 24 bumper on a 21-23 for...reasons 😅
Saw a 2024 rear bumper today. Looks super good in black and it’s steel. Wish someone could have a part list
I was going to hold off on posting, but figured I’d share.
I have an entire 2024 modular bumper and parts ordered. Some parts are in and others I am still waiting on delivery, it seems the wings and plastic fog lamp inserts are hard to come by.
I may go to the dealer and pick up what’s there and start on test fitting later this week.
After looking at the Raptor R Modular bumper (which the center sections are the same as the tremor) and taking some rough measurements, I’m extremely confident it will fit with the 21-23 lower grill trim piece. Which would make this a direct swap.
My concern is the 21-23 orange tow hooks may not work as the design is different and seem to have a different bend to them compared to the 24 tow hooks…which are only available in black. Minor issue in the large scope of things.
Speaking of the Raptor R Modular bumper, there are a few on eBay for sale right now for under $600. Which does include the center section, wings (which are longer and don’t include the fog light plastic), the plastic caps to cover the mounting bolts, and the rubber trim pice between the bumper and grill valance. A less expensive solution than buying all OEM Tremor components. I may grab one off eBay and check the fitment, just to see if it would work as well.
I will keep everyone updated once I get the parts and can get it test fitted.
You wouldn't believe it if I told you, but I've been eyeballing the raptor r bumpers myself noticing that they are quite similar
I am pretty sure the center sections are identical as the accessories for the raptor r and the tremor Modular bumpers are the same for both trucks. Which is what makes me think they are the same parts, just maybe a different color or something to justify different part numbers.
I may have found the wings in stock at a dealer, so I’m enquiring to see if they are actually on the shelf. If so, I will buy them and have them shipped. No one seems to have the fog light inserts though, I might just make a bracket to hold a couple small pod lights in them if I can’t get the inserts.
So you are saying buy the Raptor R one, then buy the tremor specific wings / fog insert separately?
Are you also going to do the rear black steel bumper? I saw one in person and want it even more than the front bumper
Not 100% sure but the Raptor r bumper looks like it's not as low on the ends, I'm pretty sure the raptors don't have front crash bars. The tremor bumper looks more full on the ends.
If you got the Raptor bumper, I think you may have to remove the front crash bars.
I’m thinking that the Raptor R bumper with the tremor wings would work. But until I (or someone) actually tries it we can’t confirm. I do know the winch mount accessory is the same for the Tremor and the Raptor modular bumper so at least the mounting points are identical. The Raptor modular bumper is black, the Tremor modular bumper is more the dark gray color, hence the different part numbers.
I did order a Raptor R modular bumper off eBay to test fit as well so I can see what works.
As far as the rear bumper, mine is steel and has the cut outs for the exhaust. I didn’t think the rear of the 2024 was any different. I know the Raptor rear bumpers are different, and might eventually do that one but we all already know that’s an easy bolt on modification.
I thought the same as well, that the sides look different, which is why I’ve ordered the raptor r bumper too to see if it really is.
True the raptors don’t have crash bars, and I’m wondering if the 2024 has different front crash bars, as the ends of the Tremor modular bumper is cut higher than the regular bumper. It’s something will certainly look at during test fitting.
To be honest, if I have to remove the front bars, or modify them, then I will. I know not everyone will want to do that, so when I test fit I will leave the OE ones on and see what it looks like.
I will certainly post up pictures when I’m working on it.
I will likely start a new thread once I do get to working on it just to keep everyone in one thread.
FedEx shows delivery for some parts on Friday. I will grab the parts already t my dealer on Friday as well.
Raptor R bumper shows delivery on Friday as well. Hopefully this weekend will be an eventful one.
Pre 2024 Tremors have a painted rear plastic bumper cover (at least my 2023 402A does)
The new 2024 Tremor which I compared side by side with my 2023 is a black (not paint matched) and steel
See attached photos of a 2023 and 2024.
If someone can give me the part numbers for those black pieces circled in red, I might order them. It looks like it would easily swipe (same shape as our current ones, just black steel)
See attached photos of a 2023 and 2024.View attachment 30952
I have a 2023 401a and it has a metal rear bumper (literally just went out and put a magnet on it) not plastic. Mine is black, but it’s painted to match my Agate Black truck.
Yes, the 21-23 are all paint to match, it appears the 24 trucks are all going to be that very dark charcoal color.
I cant see how it would be a plastic cover, as there is no structure behind it to act as the actual bumper. The tow bar is part of the rear bumper, but it doesn’t act as the actual impact protection.
This looks just like the 21-23 bumpers, so you could order them in black (or unpainted and have them painted) if you’d like. Mine are metal already.
I am considering doing the raptor rear bumper. See this thread here
Post #6
