295/70/18 Mickey Thompson Baja boss
putz173
Stratford, ON
2022 Tremor 401a
Can confirm these fit with no rubbing for me (2” level)
Also fits in the spare tire area fine
How does the ride firmness compare to stockers? I'm assuming these are e rated tires.
Have them at 40 psi and they seem fine, surprisingly quiet, you can feel there is a stiffer sidewall there and the extra weight when braking but to be expected for E rated, have a travel trailer to pull, i imagine you could drop them down to recommended pressure for a softer ride
I had them on a Trail Boss for about 10k miles. Best all around AT I ever had and best rain tire I’ve had. Only knock is they are a bit on the heavy side.
This is one of the tires I'm considering when upgrading. I've read many positive reviews on these tires. The only issue I've ever seen was with balancing.
Looks good. Do you just have a spacer level? how is the ride. I am still contemplating 2-2.5" spacer or RC M1 3" coilover.
If you plan on doing any offroad work save yourself the trouble and get the coilover. You'll be much more happy with it either way.
True I had one of the 4 that needed a bunch of weights but did balance.
just the readlylift 2" level ford installed, only offroading i do is farm lanes and corn fields for hunting season
I am second guessing from my own experience. Thanks
