2W Generator is so loud now
JordanB7
Canada
2021 Tremor AMB 402A
I’ve had the truck a little over 2 months and in the beginning the 2W generator didn’t make a noise. Now its super loud. Has anyone had ford replace the fan to make it quieter? Or any solutions? Thanks
I believe the Raptors have a TSB for it to change the fan. I'd imagine it would cover all 14th gen F150s with the generator.
*Not my image
  • a29030d5_c475_49a3_99e9_8fe8f6fe8489_633293aea2ec2385e22acbd831bb687e90520317.webp
Thanks, I will call the dealer tomorrow to see
I can confirm the software update shuts it up. You get a little fan noise when you first start the truck then it immediately spools down and stays nice and quite.
Really? So they just do a quick update? Can it be done with forscan? Thanks
I updated mine myself using FDRS (same thing the dealership will use). The changes maybe more than just as-built so I do not know that forscan alone will do the trick. If you want to try forscan first: here are the changes to as-built the update makes. Blue is before and Green is after. DCACA module.
Awesome. Thank you. I will see if i am confident enough to try forscan foe this one. If not i will get dealer
So talked to the dealership and they seem confused even with me showing them the info you sent. And its getting louder.
@JordanB7 There is a TSB for it. It is a quick software update.
Tell the dealer to look up:
SSM 50167 - 2021 F-150 - Fan Noise From The Rear Seat Area
@Robb1 awesome. I just contacted the dealer and they said yep that helps and booked me in for Wednesday. Thank you. I will keep you posted on progress
