325’s on oem wheels
racert17
Kelowna BC
2022 Tremor
If anyone is curious, these are 325/65/18 on the oem wheels with a 2.5 level.
Tires are Goodyear Territory RT in a D load, oem wheels with the factory General atx weighted 86 pounds on my scale, i ran 2022 oem raptor wheel/tire combo 315/70/17 BFG load C for winters, these weight 93.6 lbs and these 325 on the oem wheel weight 91 pounds.
0 issues with rubbing
I was just about to say that someone was asking about this the other day. But then I checked, and it was you! :ROFLMAO:
I like the tires you chose, and they look good on the Tremor! As long as you never go off-road, you should be okay. For those considering this, it's still not something I would recommend. Just because it physically fits doesn't mean it is a good idea.
I know others have asked about fitment before as well, so I have attached a tool that could be used as a guide. And I know that the calculators generally err on the side of caution, so take it with a grain of salt. But the recommended wheel width for a 325/65/18 is 9".
yup, that was me..lol
I don't "off-road" my truck except for forestry mtn roads, the 325 in basically a metric 35/12.5 except a tad wider.
I went with this 325 because of the Load D and the weight and the price point, quite a bit cheaper than a 35/12.5/18.
I have your typical level in the truck now but Friday i am expecting my halo 2.0 and UCA, this will be installed early next week.
So….they had major issues balancing the 325’s, had them on and off twice and still had issues balancing without huge amount of weight…I ended up switching out those for a set of KO2 305/70/18
Sorry for the thread revival did you notice any difference in ride between the load range D vs. E (KO2 I assume)
