402A headlight bulbs swap
JordanB7
Canada
2021 Tremor AMB 402A
has anyone looked into or swapped the headlight bulbs to the F150LED ones in a 402A package? Thanks
What headlights do you have now? Halogen or the quad LED? You can swap the headlights, but you’ll need a plug & play harness. The harness is approximately $500. I have a set of new headlights for sale.
I have the quad LED but was looking to go a little brighter cause the way the lights move the seem to point down a lot more till smooth ground then level up. But $500 just for harness yikes.
Yeah, you’d need the lights and the harness.
There are no bulbs in the reflector LED housings. They are sealed units with custom assemblies.
I have the quad LED
Are you sure? Because you say you have a 402a, and your picture there shows the projector housings (thin LED turn signal bar).
Either way, those are also sealed custom units.
In order for those lights to work correctly you also need level sensors that are attached to the suspension. You can probably get the parts but I'd assume there is more to it than just the parts.
