Added Amp Power Steps
TxT
Dallas
2022 F150 Tremor
2018 Expedition Platinum
Took off the running boards and added the amp research power steps!
Mine should look similar. Have a 2.5” leveling kit being installed on 2/1.
Looks incredible man.
I was hoping Rock Slide Engineering would design something for the F150. Electrical steps AND built with steel so they double as rock sliders. Unfortunately they only do jeeps and Broncos😭
Maybe the Bronco 4 door or Gadiator steps will work. I’ve just sent them a message to see what the say.
Those amp steps look really nice too!
Nice! They auto deploy?
Install them yourself? Difficult? Got a link?
You peaked my interest 😅
They auto deploy when you open a door.
They also have Leds that shine down on the step, one set for each door.
I did install them myself (2nd time I’ve done it),
They estimate 2-3 hours but it took me a little longer. Not difficult but a good bit of work involved. They bolt right up to the factory studs used by the factory boards but you have to run the wiring harness from the battery to each board and then also to the cab.
I had grabbed a wrong wire in the cab so took me a bit to figure that out. Supposed to splice off a green with blue stripe and I had spliced off a green with purple stripe. Had to get my light up magnifier to see that because the wires are pretty small lol.
But they work great and look awesome.
I’ll get some more pics later today with them down and working when door opens.
Damn that looks great.
So far you have a 2.5" level kit and these steps? Any other changes? For some reason your tires look beefier to me. Look amazing!
Those look great, adding to my wish list.
I did install them myself (2nd time Jve done it),
Those are the big add on’s I’ve done, also did the retrax mx bed cover, bed rug mat, shorter antenna and wheel well liners.
Those tires look a whole lot bigger. Can’t believe they are stock. Maybe it’s the optics without the stock running boards
Looks great and thank you for the photo and play by play of the install process!
Can you provide the model # of the steps you used? Looking on the Amp website, it doesn't have a selection for Tremor. Thanks for your help.
It’s the AMP76152-01A.
They aren’t model specific , just need for a 2021 supercrew. (They don’t list 2022 yet but the steps all mount the same to the various models)
For all you guys adding the powered steps and removing your OEM Tremor steps, I am in need of a pair. If you would like to sell your take-offs, I would be interested. Save the box and maybe we can get them shipped if need be.
Much appreciated. Reach out, thank you.
