Airlift airbag install bracket?
116Rob
Michigan
2022 F-150 Tremor
I installed a set of Airlift bags this morning. During the install I removed a OEM bracket/linkage above the rear drivers side tire. When I went to install the lever mechanisms don't look correct to me. They appear bound up and the bottom linkage is almost rubbing the leaf springs. Can anyone share a photo of what there's looks like? I should have take a photo prior to removal!
THe upper arm should be just about parallel to the ground or even pointing up slightly.
Looks like you need to take the bracket off and flip the elbow joint so it is up instead of down.
