Anyone know water fording limit
gfortunato915
New York
2021 F150 Tremor
Hey all,
I recently received my 2021 lead foot 401A Tremor. Ive been trying to find out what the water fording depth for this truck is however I cannot find it. I know the f250 tremors can ford like 33 inches of water. I would think our trucks would be able to ford more water than a regular f150.
does anyone have the answer to this question?
Thanks
Since the Tremor has a standard 3.5TT, I'm guessing it's the same as a regular F150 + the Tremor lift. If it was higher, I'm sure they would have put it as one the features in the marketing.. That's just my $.02
EDIT: I re-watched the Tremor commercial and found this..
Hey all,
Thanks
The F150 owners manual only has wading under Raptor specifications.
EDIT: I re-watched the Tremor commercial and found this..View attachment 958
I'm reading this as no diferential breathers. Well, I suppose we could try out some tractor wheels to get 33 inches of water fording. gonna turn like (more of) a barge, though.
note to self: add breathers
I'm guessing it the same as the Raptor. If I remember correctly, the depth was based on the location of the turbos.
@Yeti with there being vent hoses for the axels I would assume you could take it deeper than the hubs. If not I'm in trouble because I've had it over the steps and to put my boat in the water it goes well above the hub.
Yup my current fording depth is 32" because I don't want to flood the cab
I read that ford advises to change the diff oil if you drive in water that submerses the axles. Extend those breather tubes! I Know this is from the towing section but read the NOTE Below.
Yup! I have mine run up through my driver's read bed frame
