AUX switches passenger footwell
Loganp
Maine
2022 ford f150 tremor
The manual says there are wires for the aux switches behind the fuse box. But I cannot find anything behind mine. Does anyone know where the wires are in the interior for the AUX switches??
they are located near the battery according to this guy.
this is what ford has to say about it.
I'd read this thread.
Basically, there are 6 wires in the engine bay behind the battery with red tape, those are hot, then there are 6 more with white tape, those with the white tape go into the cab in the footwell of the drivers side. Those are there in case you want to use an aux switch to power something inside the cab.
You'd connect the red tape wire to the white tape wire in the engine bay, and then the wire in the drivers footwell would be hot.
they are tucked high above the fuse box, had to remove trim to find them
