I attached some pics. The Baja Designs instructions for this Raptor kit is to actually remove 4 of the bottom shutters. Use shutter hole 2 and 3 from the bottom for their bracket. I believe our shutter set up is the same or very similar to the Raptor. Depth isn't really an issue. Good amount of clearance. I tried to mount on the very bottom hole of the shutters, but the bottom of bracket didn't clear. Lights would have been too low anyway. It looks like you could mount the brackets on the upper holes of the shutters, but there is the horn on the left side. Horn looks like it may affect the depth but that could probably be relocated if needed. There is the whole grill getting in the way if you were to mount kit at different heights, but I believe is doable. The shutters are easy to remove, and you can always put them back. The shutters system still functions, it's just missing the bottom 4. The kit doesn't damage or alter the shutter system in anyway. The Baja kits are pricey but if you can get brackets made similar to the Baja ones, you'll have quite of few options in terms of lighting. Going that route may be much more cost effective. Just would have to play around with fitment.
I know @ Cblaxx 19 has already figured all this stuff out a while ago and would know way more than me on this subject. Yes he is a busy dude. I was looking at the Baja linkable kit too. Can't go wrong with that either.
