23tremor7788
- Mar 28, 2023
- 2
- 0
- new jersey
- 2023 f150 tremor
- Current Ride #2
- 2004 svt cobra
Will this kit work on a 2023 f150 tremor I can’t seem to find any information about it
Glad to hear “the ride has gotten much better once they broke in”.6112s on top notch. Says right in the instructions that they work. Cv angles aren’t bad on mine and the ride has gotten much better once they broke in.
Tremor only has .5in lift from coils, the other inch is from tires (31vs33).Also curious.
Asked stage 3 and they said it’s not recommended and watched a video on an install and they got lower results as anticipated (expected due to it not being Tremor specific)…. But 5100s are working but they use the tremor coil to my knowledge and now stage 3 and removed the “not for tremor” suggestion.
My thought is we need to subtract the 1.0-1.5 we get from the factory from the clip you’d use to get a starting point…. All the trucks are sitting a little different so the down side to that is a full removal to adjusting the height.
Side note: the 6112/5160 combo worked amazing on a past truck.
Tell me more about this sway bar delete. I have done it on past Toyotas and guess forgot about it on this truck.I have 6112s with a 1" spacer, total level is 2" in the front. 5160s in the rear. Stock UCAs. CV Angles are good.
The Digressive nature of the shocks make them super uncomfortable off-road at low speeds with pavement air-pressure (35-40 psi). I usually air down to about 20PSI to make up the difference.
I also did a front sway-bar delete and that freed up the front a lot. Now I can go really fast and I can feel the 6112s working like they should. Absolutely love them.
The 6112s are on position 5 I believe, which equates to 2" on a normal F150, only 1" on the Tremor. I didn't want to max them out, makes the springs too stiff, ruins the ride. I had them at the max position and I hated it. Took it down the .5".Tell me more about this sway bar delete. I have done it on past Toyotas and guess forgot about it on this truck.
What setting are you in with the 6112s
