Bug deflector
Jstonk
Tremor of the Month 🏆
Calgary
2021 401A Tremor
She said to not use her name.
Has anyone thought about adding a hood bug deflector? The highway rocks are so bad here I need to try something. That being said I have not specifically been able to find one for a 21 Tremor. As the hood is different from a standard 21 I need to make sure to find one that fits.
In the same hunt for this unicorn
So what's the plan, get one for a 22 and see if it fits? I can't find any details elsewhere about them fitting or not.
Went as far as ordering an AVS hood shield and had to return it…need to find a vendor willing to create it for the tremor…will be getting on phone next week….going to give this some time…otherwise will look into applying PPF
I was counting on PPF. I personally don’t like the look of a bug sheild.
Ok so update: I tried installing the Ford OEM but the brackets don't reach the holes. The hood is obviously longer in the lip. This was the correct part number as per ford's website. I will have to check with the dealership this weekend. I tried a set of the avs window deflectors, correct part number as per the website however they did not fit either. Back to square one.
I installed the Ford low profile window deflectors, vjl3z-18246-a. They look pretty good. I ran the in channel ones before and I had problems and scratching on my window so I chose the stick on ones this time.
Looks good
Looks good.
Do you have to order one or two of that part number? Like does one set for ~$100 come with all 4 window shades?
Also, were you able to use your Ford pass points? I don't see an option to use those to pay.
Looks good.
The part number came with all 4 parts. I have not spent my points yet, was waiting for a bug shield.
