High_Country
- Dec 26, 2021
- 367
- 501
- Oklahoma City
- 2022 Oxford White 401A
Got my truck (finally) two weeks ago. Took it to the mountains. Have about 2,000 miles on it now.
From day one - and even during the test drive at the dealership - I've noticed what I'll call a 'clunk' from the rear end whenever starting from a stop. It seems to do it in drive or reverse and if I apply any real amount of throttle (rolling away by just letting my foot off the brake doesn't get the clunk). It feels and sounds like its coming from the rear end/rear axle and not the transmission. It is both audible and I can feel the clunk.
The truck drives great (once rolling and past that initial clunk) - specifically the transmission shifts smooth through all the gears and I don't have any complaints about shuddering or some of the common trans problems which I'm thankful for. The rear locker engages and disengages as it should.
To ME, it feels like it could be:
a) some weird slack or backlash issue in the rear end differential setup
b) loose leaf spring u-bolts or some other suspension component allowing the rear end assembly to rotate under the torque of stopping / starting.
c) something weird with the brakes (auto grabbing and then releasing?)
d) Ujoints?
I did a search on here and found a TSB for '21's (mines a '22) about needing to lubricate leaf spring pads and block to eliminate a 'frame twist pop' - maybe it's something similar?
I was hoping it would go away thinking it just needed to break in, settle in, but it doesn't seem to be getting better (or worse).
Any thoughts / suggestions are appreciated!
d) Ujoints?
