Ditch lights wiring
erickj2604
Clermont, FL
2022 F-150 402A
Has anyone installed ditch lights to the aux switches? I have the Rough Country cube lights with amber DRL, but having trouble with the wiring part of things. The hardness cable with two white cables, two blue cables, three black cables, and one red cable going to the three way switch. i disconnected the three way switch, but now i'm having trouble visualizing how to do the wiring to the aux cables and where/how to connect the ground cables.
Any help would be appreciated.
Can the amber and the main positive be powered at the same time? If you were to use a standard 5 pin relay and use pin 87 (normally open) for main power to lights and use terminal 87a (normally closed) for the amber side of things that would probably work out the best that’s how I’d do it.
Did you ever figure out how to rin this? I'm debating on a few lights and was curious how you ended up doing it.
