Drivers Seat Movement Clunk
Bend
5k on the odometer noticing when getting in and out of the driver seat there is movement almost as if the seat is loose, when sitting it’s fine only notice when lifting off and on also you can hear a slight clunk. Anyone else experiencing this? Adding this to my list of items the dealer needs to check on.
Mine does, but I’m 6’2 280 lbs so i just figured I’m to big. :ROFLMAO:
Mine does the exact same thing. Sounds like somethings loose under the seat & clunking when I get in & out.
I figured mine out. If the seat is all the way down it snags on something. If you raise it slightly, it will stop
Mine clunks no matter what position it's in. Up, down, doesn't matter it still clunks. I have found 2 screws lying in the driver's floorboard. Thinking this may have something to do with it.
