Front gear ratio
Texas
2022 Agate Black Tremor
I did a search on this, but maybe I'm not entering the correct keywords because I didn't find anything like it addressed before.
On my order summary from Ford, it shows that my front Torsen diff will be a 4:10 and then further down the list it says my rear diff will be an eLocked 3:73. This is obviously wrong...right? It's not possible to run two different gear ratios correct?
You're correct. Rear and front will both be 3.73. Ford just needs to update their system.
Yes the gear ratio is 3.73 to 1.
The is bias ratio of the torsen is 4:10.
Here is a good explanation of the bias ratio.
Pretty sure the Torsen bias ratio is 2.5:1.
Woohoo! A new fact for us to argue! It has been drama free for too long. :)
And no, I have nothing to offer to stoke the coals.
Haha. Actually I’m partially wrong. I was going by memory so I looked it up. It’s 2.5:1 under power and 2.1:1 while coasting. At least that the Raptor Torsen which we expect is the same.
So no argument, @Coachdad just got confused but I straightened him out. 🤣
