Front Suspension Specs?
Charky
Arkansas
I couldn't find this in a quick search, but does anyone know the compressed and extended lengths of the stock front shocks?
Also, specs on the front coil springs, such as:
1. Wire diameter
2. Outer diameter
3. Free Length (length of spring)
4. Number of total coils
(I'm no expert, had to look it up)
As I've mentioned in other posts, I'm planning on going with the Eibach shock E60-35-037-08-10 and Eibach spring E30-35-037-01-20, as others have used and getting a front lift of about 2.7" or so. But it would be good to know the specs on the stock set-up when talking with folks about other solutions to obtain the 2.5" front lift without going the spacer route.
Thanks!
I'm not sure everything is covered here but it's thorough
