Gasket between Front and Rear Door
808 Tremor
Honolulu
2021 F-150 Tremor (LeadFoot)
I just noticed the gasket between Front and Rear door was kind of hanging on the passenger side. Took a closer look and realized it was missing some clips that hold it in place. I compared it to the Driver side. All are there. I was missing a total of 7 out of 9. There is brackets also but the clips hold them snug. Guess somebody at the factory missed it. :rolleyes: Hopefully able to just pick up those clips from the Parts Dept. Seems more of a hassle to take in and possibly wait way longer than is needed. Wondering if anybody else noticed this? I attached some photos.
My truck had a similar issue on the passenger side. One of the clips had popped out a bit causing the gasket to get pinched and partially torn. I pushed the clip in fully, and it seems better. There was only one clip that appeared to be problematic, but others were fine. Must also be a "clip" shortage.
Ya I could not believe I was missing 7 of 9. Missing just 1 maybe 2 I get. Could have broken off or something. The gasket got pinched also so I do have a real slight tear. I know if I could get those clips I could just install. I know there are some recalls I haven't taken care of yet so I may add this when I take it in. Hopefully they can replace the gasket too.
