Half level?
Spooder
Key Largo FL
2022 F150 Tremor
Would like to bring the front end up a bit, but not to the extent of 2.5 inch level with all the expense to do it right. What about lifting the front end just one inch, or 1.5 max? Is that possible with a puck and keeping the front end suspension otherwise unchanged? Seems it might tame the extreme rake and provide a bit more clearance.
There are 1.5" lifts. I did that to limit cv angle.
Personally I am not comfortable with CV angles on a Tremor with a lift above 2", which will still leave some rake, so I will also likely swap the rear blocks to shorter ones. I hate the look of rake on trucks, and the Tremor is the worst.
I'm debating on either a 2" AS lift in the front or 1" AS lift front and swapping the rear blocks for shorter ones. In theory it should bring the 4"rake to 2" right?
Yeah, maybe just drop the rear a bit and leave the front alone. The rear shocks should be fine with a drop of one inch? I don't mind a little bit of rake given that I tow a boat.
