Help with Order!
KingAK55
Rockwall, Texas
Infiniti M35
Good evening you guys! Found my way here due to the popularity of the Granger Dealership. I’m looking to place an order tomorrow, but just need some suggestions on the must have package and any other options. I’m sorry if this is the wrong place to post, but any help is appreciated. I for sure want the 402A package/Tremor High, the roof, spray bedliner…what do you guys think of the 18 speaker stereo, bed utility package, pro power, and getting Factory sprayed bed? Thanks again!
I would hold on the spray in at factory, it adds time to getting your truck. I would add the torsen front diff, for the price it's an excellent deal, but that's JMO, pro power has came in handier than I thought it would, but if your not going to need it don't waste the money. It's about 50/50 on the moonroof on here, I have it and so far haven't had issues.
Not sure what is standard on the 402a vs the 401a (what I ordered). Consider the interior work surface, sliding rear window, and like he ^^^ said, the Torsen front diff.
Do you have certain and often towing needs? Look at the tow packages.
I also need to take a detailed look at the differences of the 2 packages early tomorrow, this all happened so suddenly lol. I don’t have any towing needs currently, and to be quite frank not sure of what the Torsen is meant for. This is really meant for a cool looking Dad/commuting to work vehicle lol. I likely won’t be doing any off-roading, but if it’s a good deal, I’m all about it haha.
With the spray bed, have you guys found better products/price outside of the factory?
Based on the above, you certainly don’t need a Torsen diff. Some will argue it’s good for resale, especially if selling in just a couple years. It’s off-roady hardware and the truck is plenty capable without it if you don’t have specific or frequent off-road adventures.
Liners - Most people seem to feel like they get better quality from a local Line-x or similar commercial spray in place.
Thank you so much. Definitely helps.
I will add I think the torsen is a great safety feature if got drive in rain or snow. And it's one of the cheapest options. I'd skip a sunroof but I wouldn't skip torsen.
If you commute a lot, consider bluecruise.
Most everything has been mentioned it looks like, but I don't recall seeing the start/stop delete. If you don't care for the whole start/stop technology, I'd highly recommend deleting that w/your build.
Another vote for torsen. With the 402A package you get a different transfer case allowing to drive in 4WD auto powering all 4 wheels as needed.
Seems like enough momentum to add this since it doesn't break the bank anyways. Side question to the Torsen, is there anything that it changes to the vehicle? Does it change MPG, everyday ride quality (better or worse), anything different that needs to be done for maintenance?
It will have maintenance down the road afaik but not anything crazy. It's basically for traction improvement, it's a raptor part.
Also +1 to the auto start/stop delete.
