Help!
BOX71
Kingman Arizona
2025 F150 Tremor
I bought a 2025 F150 Tremor. Looking to put 35x12.5x20 tires and aftermarket wheels on. I have installed a 2.5 inch lift kit. Any recommendations on the what wheel offset should be used that will not cause any rubbing? Thank you for your help!
Someone in a thread mentioned no more than +18 unless you want to trim and/or rub.
Positive is best. anything from 18-25 will accommodate a 35 nicely.
Did you buy Raceline Gauge wheels?
OEM Raptor wheels at +35 ish fit best.
OEM tremor wheels have a +34 Offset. Follow Ford's lead and get something close from +18-+35 Offset. Seems to work really well.
Probably going for a certain look with the 20", but a 17" tire / wheel combo might give you a better ride (more side wall) and additional wheel choices.
