Hood Lights
zarc14
Florida
21’ F150 Tremor
16' Mazda Miata
Ran out of daylight so enough time to just place them…still need to connect…kept it in the f150leds family….up to AUX 5 with this install lol
Looks good! What colour did you go with??
Went with white…raining today but when i get them connected will update post with some pics they are suppose to be very bright…well similar to the back up ones I had already installed…
Sounds good! Looking forward to some photos
Stick on...went with something much stronger than the double sided tape it came with
I got the same lights but with the OEM stick on tapes. Which one you used? My worry is that the OEM ones won’t last too long.
I got the same lights but with the OEM stick on tapes. Which one you used? My wordiness is that the OEM ones won’t last too long.
To ensure a solid hold used gorilla double sided tape
has anyone measured the height/thickness of these lights? I'd really like to mount them in this slit, but fear the lights are too thick.
so 3/8" tall? Thanks!
ugh, itd be close. I'm measuring 5/16" with my calipers, but it is flexible, like they could be pressure fit in. Just not much surface area for the double sided tape to work. I'd want to throw a ziptie around em and ruin the clean look.
Sweet, could you share a pic? Thanks!
Finally got the chance to take pictures. Lmk if you want to see them on day time when they are off.
Looks Terrific! Really looks great and bright! Yes I'd really appreciate a couple Closeups with the lights off To better see the install, especially the center light where I assumed there would be some trimming involved. Thank you!
Ditto on the day pics…looks awesome
