Installed Bilstein 6112's and CV Boots are rubbing
JCW3300
West Virginia
2023 F-150 Tremor
I just had Bilstein 6112's installed on my 2023 Tremor, set at position 6, and now the CV boots are rubbing. Has anyone else had this issue?
LCA adjustment make a difference?
Do you have some pictures?
Photos of where the UCA is bolted to the frame showing bolts/nuts?
Something is wrong. I have 6112's on two separate Tremors and they do not rub.
I talked to the guy at the shop about that and he didn’t think there was a left or right. Should the angle on top lean in or out?
There is a left and right and it’s very important for wheel caster to ensure left stays left and right stays right. The strut should be further towards the front of the truck where it mounts at the lower control arm than at the top in the strut bucket on the frame. The shock top hats being installed on the wrong sides would mean they’re 180° backwards and would be pushing the strut the opposite way which is what appears to be happening here. What did alignment say for caster angle?
I didn’t see the alignment papers so I am not sure. Should I be able to take them off and switch sides? Thank you for the help, much appreciated.
No worries, I'm not sure if it'd even show up different but the geometry of the shock body itself would change the ride experience for sure I'd imagine. Yes you should be able to just swap them around but that's if in fact they are swapped. I don't know what else would cause this other than that issue but I don't have a way to guarantee it will be the cause.
Mine is close but doesn’t touch.
I got mine already assembled and they weren’t side specific(that I remember maybe I got lucky). They are a quarter inch longer in the front (forward facing) vs the rear measured from the top hat to the lower mount. I don’t know how you could get them in backward. If it’s what @ApolloChurchill said, they would have to take the shocks back apart. Maybe the LCA is all the way to the rear? That should make the caster too small. Get that alignment sheet and see what it says.
Looking at my originals, I may just be overthinking that they are. I remember sometime somewhere it was mentioned they can't be swapped but I could be imagining it for something else. Looking at the top hats of mine it would appear that the kickout would be the same no matter which side it went on so I think something more may be going on here with OP than what I said. The top hats can only go in one way and don't seem to be left/right dependent but are directional so that front is always front.
Here’s an install video that might help.
This is on my 2021 tremor. I bought them pre assembled from shock surplus in the 2.5” lift ring. The top down photo shows mine do not rub at all. Also added a front and rear view. I’ve offroaded mine as hard as these shocks can be pushed and had zero issues. I’m thinking yours are assembled incorrectly maybe? Hope this helps
