Loud clunk right before tailgate closes
TX_Powercat
Fort Worth Texas
2013 F-150 Lariat SCrew
My power tailgate makes a loud clunking sound right before it latches into place. Sounds like something is catching or binding. Has anyone experienced this? Planning on having the dealer look at it when they spray on the bed liner.
Same here. I’ve got a small punch list of items that I need looked at. Let me know how it goes for you because it definitely doesn’t sound healthy.
I also have this issue. I even took the work surface panel off the tailgate to see if I could see anything catching on the inside but no luck. Mine happens just before the latches hit the pins so I know for sure that they aren’t the problem. I’m curious to see if there is an actual fix for it.
Yep, mine is the same as yours. Definitely sounds like something is catching right before it closes.
Mine too..... let us know what you find out
Have t had it checked. The aftermarket team was different than the service team so I’ll wait until I change the oil.
miraculously..... mine quit making the loud popping noise on its own.... about a week ago.
I guess it fixed itself, idk?
Have an oil change tomorrow and tried to get the tailgate issue added to the appointment. The dealer said I had to make special appointment for repairs and October is the earliest they could get it in…Glad I don’t have something really wrong. It does seem to be getting better as the tailgate is used.
