Module Build Data ?
Fozzy
Utah
Atlas Blue Tremor
For those of you that have ordered their Tremor and tracked its progress. Have any of you viewed the Module Build sheet after it says "built" or shipped? Just wondering if all three columns are full on the entire sheet. And if any of them have the ECM populated. Still on "Chip Hold" and I have about 30 spots that do not have all three columns filled and no ECM info. Thanks
For some reason its not letting me put the link in this thread.
motorcraftservice.com/AsBuilt/Details
Not sure you can tell anything by the gaps. I checked out a truck long since built and the PCM info is blank, along with gaps in the BCE Modules. I'm guessing the gaps have to do with your trucks options.
The "Tear Tag" is the configuration sticker applied to the PCM, so I think that's your indicator for that stage. Mine populated two days after the BCE list.
Thanks,
My Tier Tag is KDJ1. I have every option available for the Tremor. Some of the blanks could be for PowerBoost stuff and electric steps, that I would not have? Just wonder if I could see any "Chip Hold" progress from this tracker.
Some people have put some weight on the modules staring with 754. I’m not sure what that module is or what the importance is. So basically, I have nothing to add here except a bit more confusion.
Yeah, The same modules are used across the lineup, which means even having the BCM programmed for heat/vent seats would be different from just heat.
You can check this vin from a random F150 Limited and see how it's full of holes, too: 1FTEW1EG9LFB55115
EDIT:
So, went back because I had to refresh on ForScan since I haven't gotten my truck yet so reached a point it wasn't worth staying on top of. You can see some lines just don't get filled. Here is a random line from the Image Processing Module A. ForScan shows it as only having values in the first block.
Seen in the AsBuilt for my truck that's listed as Chip Hold
These boxes aren't supposed to be populated.
BUT, you can tell what modules are programmed from the first three numbers, as those are the module identification numbers. It won't let me share the sheet, but you can look up the numbers on the ForScan spreadsheets. While again, there will be some you won't have, like 712 Multi-contour Seat Module if you don't have the fancy seats from the...Limited?
You've now sent me down a hole where I'm comparing my modules to the list, and just starting I'm seeing 721 Vehicle Dynamics Control Module...but that shows up on a Raptor VIN and not Limited VIN...so probably having to do with Live Valve?
That's the Telematics modem. You can see this installed when the app or Ford.com says you can activate your vehicle in FordPass (but you can't until you're with the truck), fully active when your Ford account thinks you can add a mobile hotspot plan.
751 is the closest I have to 754 :(
