No. Many of us have gone this route to include those of us with BC.Any impact to the sensors or cameras? Did any of that need to be recalibrated?
Tire and wheel specs? Are those 35’s? Or 315/70’s? What width/offset for the wheels?My current Tremor build. Been a work in progress but happy with the results from everything.
The way you have your build is what I’m looking for could you share your lift kit model and make and looks like you’re sitting on 35s?My current Tremor build. Been a work in progress but happy with the results from everything.
Need more pictures!My current Tremor build. Been a work in progress but happy with the results from everything.
What is a 2.5 AS LEVEL? could you give more details on this leveling?Wildpeaks and 2.5 AS level
2.5 puck level from Auto Spring. These are pucks that sit on top of your strut assembly providing the lift.What is a 2.5 AS LEVEL? could you give more details on this leveling?
ok did you have to change the control arms too? cause itll put allot of angle on the ball joint too no?2.5 puck level from Auto Spring. These are pucks that sit on top of your strut assembly providing the lift.
I didn't wheel with the spacers so couldn't answer that for you. Hopefully someone here can answer that for you.ok did you have to change the control arms too? cause itll put allot of angle on the ball joint too no?
im confused. you said you did a 2.5 puck level from auto spring, the 2.5 puck is the same thing as a spacer, or are you saying you changed the whole coilovers?I didn't wheel with the spacers so couldn't answer that for you. Hopefully someone here can answer that for you.
I have done both. I had the AS 2.5 pucks to level the front and then went with Icon Stage 3 suspension afterwards. That said, I would have gone straight to Icon if they had been available at the time. I did change the UCA when I did the coilovers but not for the leveling pucks.im confused. you said you did a 2.5 puck level from auto spring, the 2.5 puck is the same thing as a spacer, or are you saying you changed the whole coilovers?
When level kit was installed did you have to recalibrate the collision control and lane detection? Alignment shop says I NEED to recalibrate after leveling.Wildpeaks and 2.5 AS level
I did not.When level kit was installed did you have to recalibrate the collision control and lane detection? Alignment shop says I NEED to recalibrate after leveling.
