My weekend projects
Texican
KS
The weather cooperated yesterday and today and got to clear out the add-ons that were piling up.
Started with bed rug impact liner and Leer HF650M Tonneau cover. Both were fairly easy to install. Beware that the templates for bed lights on the back side of the cover are not very accurate.
Next up were the BDS/FOX 98224828 shocks. Easy install and ride quality is awesome so far. Hit washboard and gravel roads at 60+ and truck was planted the entire time. Also added husky liners while I was at it. The shocks are a little long compressed so a spacer for the bump stop is required. I used a timbren spacer.
Final add ons were new black lug nuts, valve stem covers and Tuxmat floor mats.
@Texican, those Husky liners look to cover a lot more than the factory Ford ones. Is that an extra piece or are they just that big?
My Factory Ford liner
Well, I guess I will be getting a set. Probably wait until I get my airbags on. My last F-150 I had to trim the liner. Not sure if I will need to on this setup.
Shoot me a pm before you order. I’ve got a set in the garage but I think the truck I’m getting already has them installed.
When ordering the Husky liners do you just select “Lariat” for the trim level?
How soft or cushioned is the bedrug? Debating on getting one myself when my truck comes in but everyone I know goes spray-in route.
I got impact liner and it has a rubberized top. It is still very comfortable to crawl around on. You could definitely sleep back there. I was going to get a spray in but after reading the reviews and then installing mine, I am very satisfied with it.
Which lug nuts did you go with?
