Need a Ditch light bracket recommendation ( that doesn’t interfere or hit antenna when swiveling )
Badmothertrucker
North Carolina
2021 F-150 Tremor
Just like title says I need a Ditch light bracket recommendation that doesn’t interfere or hit antenna when swiveling. Ideally black powder-coated.
I bought one from Amazon but it sits right behind antenna and won’t allow swivel movement.
Thanks for product solutions!
Had the same issue and bought BD lights that have a more forward mounting location (i.e. light further back) and now have no clearance issues depending on how far out I need to direct the lights.
Diode Dynamics has mounts now. They shift the light more to the outside.
Sdhq are the best in the game. No comparison. Just depends on your pocket though. I got some that were installed and removed for cheap AF or I wouldn't have bothered.
I assume you wired these to an oem switch? Did you use one for the backlight and another for the leds?
When you buy the pair do they come with the brackets? Website didn’t make that clear.
If you are looking at the lights themselves, then no. The brackets are included. If you search via vehicle list, it will show a ditch light kit for the 21+ F150. That kit includes the brackets and harness.
