New F150 Truck Topper - Narwhal
modified
Admin
Staff member
Austin, TX
'25 F250 Diesel Tremor
'21 Ford Bronco
Narwhal is launching a new carbon fiber truck topper for the F-150. The Narwhal Mk1 Topper is significantly lighter than traditional aluminum, steel, or fiberglass competitors, with weights ranging from just 90–130 lbs depending on configuration. This lightweight design makes installation, removal, and everyday use far easier, without sacrificing strength or durability.
Some of the features include:
Full Carbon Fiber Shell
• Full carbon fiber side panels
Removable rear panel hinge system
• External L-Track mounting rails on roof
Premium LED brake light + (2) Diode Dynamics internal rock lights
Premium locks with full set of keys
• Internal L-Track mounting rails for accessories
Premium gas struts on all openable panels
Positive air pressure vent to reduce dust intrusion
• Side panel accessibility
Full bolt-in mounting bracket system
• Anodized and powder-coated hardware
Premium front slider window
• Standard privacy glass on rear window
Automotive UV-resistant clear coat.
More details can be found here: https://narwhaltrucktoppers.com/
Base version for F150: $9000...
That's $5K more than my SmartCap cost me (EVO)
185ish pounds lighter which is a lot but for some reason I don't care.
I'm sure all the billionaires out here will have them on their Raptor R's in no time.
Not me
I'm not really into the toppers that don't follow the body lines of the vehicle. They all look like some weird addon to me. That said, this one isn't awful looking to me but that price....
There is a good point...aerodynamics.
First topper I’ve seen with a turret hole. In the event you need to mount up a ma deuce or MK19, you are good to go.
Yeah, sorta too Couchcommando/LARP'r look to it with that turret.
That carbon fiber couldn’t handle the force hahaha
