New tpms sensors
Carbongrey
Canada
2025 Tremor
Hey all,
Just put winter tires on my new 15 tremor . New aftermarket tpms sensors (433mhz I believe). My scan tool from my 18 f150 doesn't activate them for some reason.
Do the new 2025s not require a learn tool, or am I doing something wrong ?
I just added a tpms sensor to my spare and used the $15 amazon button fob to do the relearn(ignition on hazard button 6 times follow instructions). Mine were 433MHz. I have a MaxiTPMS which scanned them just fine.
Edit: Used OEM sensors
Edit: Used OEM sensorsdi
Did you use the $15 one button Amazon fob or the $300 maxi?
😂 The $15 fob, easier and smaller. The maxi is for when there are problems and you have to check the sensor, read serial number etc. If the easy way doesn’t work you have to use FORScan or the maxi to enter the Serial numbers directly.
