On board generator
Oliboy90
Hawaii
2021 F150 Tremor
I thought all tremors came with a generator. My tremor doesn't have a option to turn on and off the generator. Am I the only one. Please help
Look in the features section of your screen for pro power…left on tailgate you should see a plug…this was an added option on vehicle so don’t think they “all” necessarily come with it…
Ya I don't have that. Kinda pissed about that. So basically I only can you that plug in my bed if the truck is on. Which really blows
The 2kw pro power which is the only pro power option for the Tremor requires the motor to be running in order to get the 2kW power. It’s a $1000 option that I did not order, as I did not see the value and looked to be an expensive maintenance item.
FYI, Pro Power adds an additional alternator basically in the engine to make this power. Which means more drag on the motor by the additional pulley for it, which constantly is spinning.
The plug in the cab and in the bed is 400 watts standard without the pro power.
I didn’t see much benefit to the 2kw pro power to me personally as I wouldn’t use it very much. But I’m sure others would use it all the time.
An additional factory alternator may not be a bad idea if your thinking about adding a winch at a later time.
That's true. Does the truck have to be running or just be on the on position???
2kw Pro Power would be nice to have. I didn't order it because the inverter takes up the under seat storage area. I need that storage and don't want to lose floor space with the lockable fold flat storage.
Just my opinion.
