On Board Scales
Bakes
Air Force
2012 XLT F150
After digging around the newer tow guides I noticed the tow tech package lists on board scales as being included. Also didn't see any notes excluding tremors. Also saw a thread on the gen14 forums saying scales don't require CCD. Can anyome confirm if tremor tailights have the load indicator leds? And has anyone tried to activate the scales with forscan yet?
  • 2022_Ford_RVandTrailerTowingGuide (1).pdf
It has the scales. I just got called that my readylift airbags don't fit because the scale is in the way, so they need a bag that goes on the frame instead, or go with the RAS.
Actually forgot about it until now, plan to look for it in the settings as soon as I get it back later.
Can you check to see if you have the hardware on both sides of the truck? Apparently all our trucks have them on the drivers side for the auto leveling headlights.
It is on th drivers side, the installer specifically told me that.
Those are for the headlights then. It's the same equipment minus the right side and an extra module.
From what I read it's not an active scale where you can read the current weight in the bed. It just makes the light blink if you are over the weight limit.
