Quiet possibly the craziest thing I've seen!
FaKtor34
Moderator 🛠️
Staff member
TN
Retired Army
F150 Tremor iconic silver
Yes I know but it's a CrossFit plate not ar550.
Are they exclusive? I'm guessing they purchased a bunch of old plates as part of the schtick.
It's the weight plates that CrossFit people wear to add weight when they run, they weigh 13lbs.
Weight Vest Plates by Tribe WOD Plate Carrier Weight Designed for Men and Women, Work Out Crossfit Plate Carrier, Pair of Steel Plates for Weighted Vest, Training Plates for Plate Carrier https://www.amazon.com/dp/B09KJF661N/?tag=f150tremor-20
yup and they look exactly like those old Korean Marine steel plates. AS for hardness, I fast forwarded through most of it but that is also acting like AR 550 unless they had ceramic in that carrier, too.
Yes I know that's the crazy thing, $89 for a plate that apparently is capable of stopping 7.62x51. If there were a way to verify that's some cheap level 3 armor. Also there was nothing else in the plate carrier other than the plate itself.
lmao, and HEAVY. Honestly though, that's a heck of a target for $90
They also have 8.5 lb plates, wonder if I sent them those if they would run them through the same test, coat them with bed liner before sending them.......hmmm.
Reactions: ETN
or, take a trip and we'll beat the crap out of them from 9MM to 300 winmag
Well that's an option I have .380, 9mm in compact, full size and rifle,5.56, .243, 6.5 creedmoor, 7mm rem. And .410,20,and 12gauges. Hmmmm might have to meet up or if we do a meet up trip at windrock do it then.
I've 20 acres for a back yard and a pretty good sized hill as a backstop. just sayin'
9s, .40s, 10s, 45s, 5.56, 7.62, .300 WM and a .338 Lapua and .50 BMG (neither of which I will shoot on my property)
I understand not shooting either on your property, I have one piece of property that I would shoot either on but that's only because you would be shooting straight into the side of a mountain, but you could only get about a 300 meter shot. Most ranges won't even allow them, we have 3 around here that do out of about 10, only one is further than 300 yrds
