Raptor Transmission Cooler Install
ApolloChurchill
San Antonio
F-150 Tremor
On my off time the last two days I completed a long time goal of adding an air to oil cooler to my Tremor. Why they don't come with these from the factory is beyond me as these trucks seem like the perfect candidate for them. Word of warning: the install process is rather challenging, frustrating, and inventive. I'll start with the parts and summarize at the end how I go this wrapped up.
Ford Parts direct link to the cooler manifold
Ford Part Number​
Notes​
MSRP at time of posting​
ML3Z7869B
"Oil Cooler" - Manifold that takes engine coolant to warm the transmission fluid with a thermostat that opens and sends transmission fluid to the air to oil cooler​
$375.83
NL3Z7A095A
The air to oil cooler that goes behind the grille​
$171.78
ML3Z7B028A
Hose from cooler manifold to air to oil cooler - Drivers side​
$180.40
ML3Z7B028B
Hose from cooler manifold to air to oil cooler - Passenger Side​
$175.27
ML3Z7B142B
Air to oil cooler mounting bracket​
$88.37
NL3Z7R081B
Transmission fluid supply/return tubes between manifold and transmission - V8 version​
$256.67
ML3Z7R081C
Transmission fluid supply/return tubes between manifold and transmission - V6 version​
$254.83
W712146S437
Bolts to retain supply/return tubes to cooler manifold (pack of 4)​
$13.00
8C3Z7Z465A
Collet latch for transmission cooler hoses to manifold (2 required)​
$11.68
W720995S439
Bolt to mount oil cooler manifold (4 bolts in a package, only 3 bolts needed)​
$17.00
W520833S439
Spring nut for mounting oil cooler manifold to crossmember (4 in a package, only 3 needed)​
$13.00
W715798S439
Stud used to secure supply/return tubes to ports on transmission housing and secures parking pawl release cable​
$22.60
W720157S450
Clip-in retained bolt for securing drivers side cooler supply hose​
$17.00
W712741S450B
Hex nut for securing the drivers side cooler supply hose​
$26.60
W520822S439/W705134S442
Speed clip and bolt to secure drivers side of the air to oil cooler to radiator​
$13.00/each
This is the key items needed, if you want to keep it OEM of course. At minimum you need the oil cooler manifold and for simplicity the supply/return tube to get you started if you were to do your own lines/air to oil cooler part. I don't know if the manifold can be converted to a normal fitting for the hoses though, they're the push connect style barbs. Also the coolant barbs are 3/4 instead of the 5/8 that supply the factory transmission mounted heat exchanger. I swapped them out with two 90° "heater core" fittings that were 3/8 hose to 3/4 quick connect. Fishing the old tubes out and then getting the new ones in was a chore, not a lot of clearance at all. I also didn't double check the tubes when going around the warehouse and wound up with the 3.5 version. Minor differences but there is a securing bracket that does not work with the 5.0. On that note, my transmission tubes came with the rubber seals attached but I'm not sure if that is guaranteed from the parts ordering side of things. Having the Whipple heat exchanger caused extra creativity as well to get the cooling radiator to bolt up but I just took some angle brackets and bent them to add the clearance I needed, this did require deleting my grille shutters but that's specific to having the Whipple heat exchanger taking up space behind the grille already. This project is definitely something for a dedicated person, I can't personally suggest doing this unless you have a real desire to have the added cooling while retaining the factory warming feature for the transmission. I have seen a few people talk about the possibility of adding this but haven't seen anyone do it so that's what more or less pushed me into the crazy idea to finally try. I also wanted to preserve the transmission as much as I could with the added power. I've frequently seen some high temps just hot rodding around off-road. While not overly concerning I knew that it needed something extra to keep temps in check.
I don't have great photos as this took longer than anticipated to get done so I was focused on finishing more than documenting. The summary of the install is you remove the grille and skid plates for access. Find and clamp the coolant lines up front that go to the transmission heat exchanger tubes and disconnect them from the tube, there is also a hanger you'll want to free up. Then you go to the drivers side of the transmission and remove the single bolt holding the park release cable (pop this off the ball stud) and transmission fluid ports of the heat exchanger to the transmission. There are also two nuts on the rear side of the heat exchanger that you take off plus a plastic retention clip for the drivers side O2 sensors you can pop up and off and then the whole heat exchanger unit can be freed. It's best to disconnect the coolant lines from the heat exchanger at that point so you can carefully dive bomb the heat exchanger out. It's a tight fit but the front driveshaft doesn't need to come out for this. Then you can unbolt the second coolant tube hanger from the transmission and begin the painstaking process of fishing it rearwards and out. It's tight and cussing and twisting and more cussing seemed to work best for me. Then the same steps to get the new transmission fluid tubes installed. Don't forget to lube the rubber seals before you push them into the transmission. Stack the park release bracket on top of the tubes securing bracket and bolt them to the transmission housing. Secure the tubes with the included hanger on the corner stud of the transmission. Back up front you'll want to mount and secure the cooler manifold assembly, the whole brains of this operation. After that lube and insert the ends of the transmission tube lines into the cooler manifold and secure with the bolts. Mounting the air to oil radiator cooler is easy enough, it snaps into the plastic frame and then bolts up against the radiator. The lines are a bit of a chore to fish through the side openings around the radiator but it's doable, mine came with the hose clamps attached. Secure any hanger brackets (I removed mine since they can't be used with the Whipple heat exchanger) and then back down at the cooler manifold you just insert the tubes in and lock them in place with the plastic collets. Change out your coolant fittings on the hoses and then you can clip those on, unclamp the hose, and you're ready to rock. You'll want to run the truck and get everything cycled and then check the fluid level. The procedure is a chore and annoying because the truck needs to be running and the transmission needs to be above 200° for an accurate level check, all while working next to a catalytic converter.
Ford Part Number​
Notes​
ML3Z7869B
$375.83
NL3Z7A095A
$171.78
ML3Z7B028A
$180.40
ML3Z7B028B
$175.27
ML3Z7B142B
$88.37
NL3Z7R081B
$256.67
ML3Z7R081C
$254.83
W712146S437
$13.00
8C3Z7Z465A
$11.68
W720995S439
$17.00
W520833S439
$13.00
W715798S439
$22.60
W720157S450
$17.00
W712741S450B
$26.60
$13.00/each
How much was it for all the parts? I’m going to have to go this route soon.
I raided the parts bins for most of what I could. If I had to get everything, with discounts it would have cost me around $600 for the core pieces
Crazy that this doesn’t come standard on our trucks.
Curious. I wonder if the parts impede slightly on a winch installation, the assembly (part 7A095A) looks like it mounts pretty forward above the crash beam mounted on the front engine cross member.
How much work was this to get installed? Also do you have a 5.0 or a 3.5
Speaking about something like the SwarfWorks hidden winch mount, it doesn’t interfere at all. Basically if it has any design intent for Gen 3 Raptors then this would have been accounted for.
The amount of work was more or less just time consuming with getting tubes and hoses where they need to be without the free clearance of an open chassis. A lot of interferences. I have the 5.0 and a Whipple so I chose the Raptor R specific cooler, it’s got a few more rows of cooling fins
Ford Part Number​
Notes​
ML3Z7869B
$375.83
NL3Z7A095A
$171.78
ML3Z7B028A
$180.40
ML3Z7B028B
$175.27
ML3Z7B142B
$88.37
NL3Z7R081B
$256.67
ML3Z7R081C
$254.83
W712146S437
$13.00
8C3Z7Z465A
$11.68
W720995S439
$17.00
W520833S439
$13.00
W715798S439
$22.60
W720157S450
$17.00
W712741S450B
$26.60
$13.00/each
Hard to beat OEM parts.
Nice job. 😎
Nice job 👍 finally, someone did the retrofit!
Quick question: where did you get the 90° heater core fittings?
Amazon, they're just Dormans lol. Maybe one of these days I'll look into the proper hoses and fittings but doubt I'll ever do it since the wye's are thermoweld clamps. I don't know if the heater core tubing is the same between 5.0 and 5.2 so I assume I'd have to splice. The proper hoses are NL3Z18472AA and expensive af
Edit: Looking at them side by side, yeah way more work. Different enough and would require a different heater control valve assembly. Not worth it
You know @ApolloChurchill you could probably make some money and create a service here if selling the kits with detailed instructions. Seems there is an untapped market.
That’s not a bad idea if people were truly interested. I know piecing it all together with nothing to go off does curb a lot of momentum otherwise.
Ordered the full parts list for my 2023 5.0 😁
The Ford dealer here in Saudi Arabia said the parts are coming from multiple countries, so it could take up to 90 days 😵‍💫
For the 90° heater core fittings, I went with Dorman Heater Hose Connector Fittings 800-419. Hopefully they’ll fit, and I’ll swap them out for something more reliable/heavy-duty later on.
Wow awesome to see someone else take the plunge. I ended up using those exact Dorman fittings on mine. Hopefully I didn’t miss anything I feel on the hook now lol. I intended to do a more detailed guide on this process but was working with a lot of limitations when I went about this that I didn’t have the free energy to document things as I was doing it.
@YAZ94 Did you manage to install this?
@ApolloChurchill Did you verify that your transmission was running cooler? If so, by how much? Was it worth it?
I'm due for a transmission service in about 4K miles so am trying to decide if I should get this done. At the very least I am adding a PPE pan.
Just so I can reference it later. Did a little work and got links with part numbers and updated pricing as of today.
Total cost even with discounts is just north of a thousand dollars o_O
@ApolloChurchill Sorry for the spam. Do you know if you *need* ML3Z-7869-B? That is factory equipment and based on the diagram you have provided, it's not needed.
I watched a video earlier and someone used the Mishimoto F150 transmission radiator here. It looks like it's meant to work with the OEM lines at first glance, wondering if you could use it instead.
No worries at all happy to help answer questions. Regarding ML3Z-7869-B that is the cooler "manifold" for lack of a better term, it's mounted on the front cross member beneath the radiator. What that unit does is take engine coolant and warms the transmission fluid, once a certain temperature is reached the thermostat opens and allows transmission fluid to flow out to the aux radiator in the grille (NL3Z-7A095-A). The factory (non-Raptor) setup houses the manifold on the side of the transmission and has coolant lines only to it so using the Mishimoto radiator you linked wouldn't work directly as they don't run transmission fluid lines up to the radiator on the P702 (14th Gen). I know they make a fitting kit for the 10R80 that allows you to run your own transmission fluid lines out to a aux radiator. The only reason I didn't go this route is I wanted to keep the thermoregulation capability of the OEM system.
To answer your question about temperature improvements, yes significantly. I did some dune trips shortly after the install and while I did also have to remove my grille shutters for clearance due to the Whipple heat exchanger, the temps were beyond satisfying and I believe would still be with the AGS system still in place. I peaked at 219° on the gauge cluster during my most intense moments and once I parked it was down almost immediately back to the 190's which is about where it stays during summer. Now that it's cooler it tends to stay right at the assumed t-stat number of the 180s unless I start getting on it or put it into Sport mode. I have been thoroughly impressed at not only saving myself radiator cooling capacity but also ensuring I don't cook anything accidentally. There's a lot of times where its high load and slow speed for me and I always wished for more capability in getting that heat out and this for sure has been the solution there.
Never mind, one of the image linked to the part in my table was showing factory equipment which is why I was confused. Yes, that part is necessary. Thanks for clarifying.
That’s good to hear about the temps. I'm going to see how a full fluid change + PPE deep pan works for me first, then if it becomes an issue I'll start putting some money away to go this route. Highest I've seen my temps is 232F, not somewhere you want it to be.
Never mind, the image linked to the part in my table was showing factory equipment which is why I was confused. Yes, that part is necessary. Thanks for clarifying.
Yeah I was seeing temps like that and it was really concerning me. I think the pan definitely will bolster it a bit. I would say doing your own radiator and lines but I have concerns about colder climates and not getting the trans to temp very well if at all. Having engine coolant act as a warmer is by design and I think validated for sure.
People have reported some pretty postive temperature drops with these larger pans, somewhere on the order of 15-20 degrees F cooler, which is substantial.
Got the PPE deep-sump pan installed. Wasn’t too bad.
Did a fluid change and a filter change (obviously). If you attempt this job try and find the fluids and filter online, Ford dealers mark them up pretty heavily. The filter was $108 on its own at my local dealer. Didn’t have time to buy it online.
Transmission report: After 30K miles the fluid still looked really good. Didn’t smell burnt, was a little bit dark, but still had a red hue to it. No glitter in the pan, magnet was clean. Filter magnet had some light clutch material on it, but other than that looked great.
Excited to see how this affects transmission temps. Already seems to be running pretty cool. Took it for a highway drive and instead of the typical 206, I was seeing about 190.
(Yes it fits with the RCI transmission skid plate).
