Rear Aux Light Setups
b-real
Utah
2023 F150 Tremor 3.5
What have you all done for some rear facing aux lighting setups?
SS3 wired to Aux 6, SSC1 wired to Parking, turn and reverse lights
Started with this setup and then shifted to dual tucked Ssc1s tapped into the hitch on custom brackets. Still need to add the harness for an AUX switch, but the zone lighting option works for now…
SPV Rear Rigid SR-L Series reverse light Kit. Got full length harness with both switch and reverse triggers. Hooked up to Aux 1. Turns on with reverse lights. Illuminates with red halo with parking lights.
I’m also utilizing the spv harness, it’s a great way to tap into your taillights!
I'm using the Morimoto light bar above the license plate frame. I dont like the clutter of lights below the bumper. The light bar is bright and comes on with scene lighting and reverse.
What does the bracket mount off of?
Check out third brake lights with integrated Baja Designs lights. Can get pricey, but very sleek!
