Recommendation for Service Ramp Set?
madeinchina
VA
2022 Tremor 402a Oxford White
I was hoping to pick up some service ramps for the tremor, does anyone have some recommendations? I got nervous when I saw well rated plastic ones on amazon that contained reviews reporting cracking and buckling... Figured I should ask the truck guys first.
Any of these.
I just watched someone build some ramps using scrap lumber. It looks like a solid option that only costs $30 instead of $1100 for aluminum. Thoughts?
Dont be afraid of plastic ramps. I had a set I bought from Canadian Tire and they worked great for my 2500 diesel truck and it weighed allot more than my tremor. Just buy a good quality set like the Rhino and you should be good to go.
But of course always use axle stands after it is on the ramp just for safety of course like Everybody does........
What do you need the ramps for? Oil changes I would assume? Personally I have always done my F150s just on the ground as I find enough room to slide under there without ramps, but also without a creeper.
Get a jack and jack stands, you can do so much more maintenance.
