Rocker Panels
LawBringer
Flowery Branch, GA
2022 F-150 Tremor
Ford Explorer
On My previous F-150 FX4’s I took to a local Rhino liner and had them tape off and spray on a rocker panel(s) following the then straight molding.
Always looked good, almost perfect but, we all know the owner (probably only the owner) could see any imperfections. This application always worked like a charm and performed flawlessly.
Nothing but compliments
The lines on the most recent F-150 bodies have the curvy rocker line, looks much better IMO, but does cause some angst in attempting this on my 2022 Tremor.
My question I guess is why can’t Rhino or Line-X create individual panels that are laser cut to be installed at home by a DIYer or by a local professional?
Hoping someone in here knows of something like this or maybe one of these manufacturers follows any of Ford threads.
Also the tape line x uses can follow any contour they want, you should get the same results as your previous truck
Clear PPF on the lower fender,rocker panel, drivers door and behind rear wheel instead of mud flaps!
A couple have done these.
^ I think I did see someone on here with them painted to match. That would potentially work, I need to compare a shop cost to paint them versus having the rocker panel PPF put on.
I think @Badmothertrucker is one of the ones who did it.
You don't have to paint them, they come as a matte black if you want to keep the contrasting color.
