Save 10% - VIAIR 400P - 40043 Portable Compressor Kit
modified
Admin
Staff member
Austin, TX
'25 F250 Diesel Tremor
'21 Ford Bronco
Amazon has the VIAIR 400P
"Features our brand new I-Beam Sand Tray for improved stability and lighter weight. The 400P is a larger powerful portable tire inflator kit that can inflate up to a 35-inch tire from 0 to 30 PSI in less than 6 minutes. Used and approved of by off road enthusiasts worldwide, the 400P can save you when you’re miles from home."
Check it out here:
I have had the that same compressor for awhile & it’s an excellent one, especially for that price. Only negative is; it takes awhile to cool down after use.
Great compressor. I have the automatic version of this same compressor that shuts off when air is not flowing.
This might be hella ghetto but we can plug a converter into the back of the truck then run the compressor using the terminal clamps off of it... Its not particularly elegant. Convert needs to be able to handle 40amps I guess.
Too ghetto for me, if I drove a Tacoma I'd consider it.
I have had this compressor for about a year. I've used it maybe a handful of times but it has always worked well.
