Sizes of guages changing?
WSH
Texas
2022 Ford F-150 Tremor
I have tried searching this topic, but wasn’t able to find anything…. But, tonight I was driving and for the first time that I recall, the tachometer and speedometer were quite a bit smaller than they normally are. I couldn’t figure out why. Then just as weirdly, they were back to the size they normally are. I didn’t know if it was because it was dark or what. Anybody have any thoughts as to why this is?
They shrink down if you have something like navigation pulled up or something is giving you a message at the top of the cluster, so either you were using nav or something had popped up with a message in the top center of the cluster.
I thought that was likely the case and I’d seen them doing that before—. This was not quite that however. They seemed to stay that way with birthing in the middle of the screen.. But then they went back to the normal size. Perhaps it was just the system “catching up”. Thanks for the info.
The Truck telemetry makes the speedo and tach smaller, the one that shows pitch and roll, and your steering position.
Also, did you have BlueCruise on?
