Tire deals!
New tire made by Falken for those looking for a little more of an aggressive tire than the at3w.
Nice looking tire. I see they make a C rated 35x11.50R18LT. They don't have the full spec's listed for this size, but I have inquired. It is a bit odd that their C rated tires seem to be so heavy, as others have noted over at TacomaWorld.
Thanks for posting!
https://www.falkentire.com/wildpeak/rt
A pdf is attached, with sizes for the RT.
Hopefully Falken will update their website, but they got back to me on the full spec's of C rated RT 35x11.50R18LT, if it helps anyone:
OD: 34.8"
Width: 11.7"
Weight: 64.2 lb
Rim range: 7.5-10"
Tread depth: 16/32
Max load: 2835 lb @ 50 PSI
One more quick update, if anyone is considering the new Falken RT's: the local Discount Tire called Falken for availability, and sounds like as of today, the RT's will hit retail inventories in about 60d, with the tire currently being in pre-release, while they build inventory.
Amazon has the Falken Wildpeak A/T3W all_ Terrain Radial Tire-LT295/70R18 129R for $289/Tire
Link:
The only thing is this first batch of the Falken RT has been having issues, the tires seem to have a serious unbalanced issue, Falken is aware and has been working with people to help with the issue and as they get new stock in are pushing it out as fast as possible.
That's very interesting. I was getting TOYO RT trails but are on national backorder so went with the Falken RTs which i was surprised were available cause thought werent out yet. My tire guys installed them and said they had a bitch of a time getting them to balance and had to add a lot more weight then they liked. What is falken doing about this balancing issue? New tires?
They have been trying to work with people on this according to what I have found, reach out to their customer service department, the issue is them getting more in stock.
Little bit of info. Well they wouldn't post, so go to you tube and watch OFFRD
4:21 minutes Warranty Saga and 3:37 minutes Finally a resolution. He explains the issue well and the problem.
Most of the info I found on them was through another forum that had a discount tire guy on it and they had an open discussion about it and said it might be 6months before discount tire could get these in stock due to the issue.
