Transmission Not in Park Message
bug892
Edmond, OK
2021 F150 Tremor - Oxford White
Well, after finally having (2) error-free months, I started getting a few new messages on Friday. When I am coming to a stop, the message "Transmission Not in Park" pops up on the display. Everything seems normal, and once I start driving again, the message goes away. This is the same message that I have "legitimately" received when I open the door and the truck isn't in Park. I've checked all 4 doors, slammed them multiple times to make sure they're tight. The horn chirps normally when I lock it (not twice like when a door is open), and the dome lights dim and turn off as normal when I start it.
As it also happens, I'm now also getting a hill assist not available message when I first start the truck.
Any ideas on troubleshooting / fixes?
Dealer tech, you have a faulty sensor somewhere and that could take time to find. I would check each door sensor make sure it looks right, it could even be a wiring issue.
It did it consistently for about a week, then stopped. Now it's just sporadic, and if I open and close driver door it usually goes away. You mentioned checking each sensor and making sure it looks right. Any thoughts on what I should look for? No idea what I'm looking for.
Did you ever find out the issue? My tremor is doing the same thing
Just make sure the sensor isn't stuck or that it is fully connected, if everything looks fine then a dealer tech will have to trace the wiring to make sure all connections are good.
Have appt for dealer on Tuesday for same issue. Will update when I have more info.
For information sake: where is the door sensor located?
Same thing here. "Transmission not in Park" and "Hill Assist Not Available". Happening to other people as well is a little suspicious to me. Wonder if that bug came in with Auto Update?
Issue started mid March for me, went away for about a week then returned
I have seen the Hill Assist not Available for about a month now. Transmission Not in Park so far only today.
