Wheel liners installed Much better
Tremorfun
CA
2021 F150 Tremor
Blends much better eh
Husky? I got the Ford ones and they do not cover nearly as much. I also like that yours have bolts rather than plastic clips.
side note: I really dig that color!
Yes husky and thank you much 🍻
Those look good but look different than what is on the Husky site
Such a simple mod but so worth it. I placed some left of ceramic coating before installing to make cleaning them soooo easy…
For others who want to compare to the Ford OE liners here are a few pics. Although no screw at the top, there are screws on bottom portion of the wheel liner.
Thanks for the beta on the Ford liners vs the Husky liners- I had no idea that the coverage was so different. I got the Husky liners because they were significantly cheaper than what I could find for the Ford OEM parts, but glad that they provide more coverage of the frame. Might even have to trim them or see if a heat mold can pull back part of the cover around the shock, as that portion is warped and may be rubbing on the shock housing. Otherwise, the installation was easy and didn't require any drilling or modification and got a pretty tight fit.
I also checked some of the online coupon sites and was able to find a code for 10% off, so if you are thinking of ordering a pair, you might want to give that a try.
Thank you for these pics! My liners were delivered today (along with Ford accessories mud flaps). Had both on my '13 Lariat and loved them!
Just installed them. Best looking mod for the price! LOL
very easy to do yourself, except for the stupid washers that go on the christmas tree fastener, its almost like the opening for the washer was too small.
Yep, I wouldn't even count it as a mod. To me it just makes the truck look complete and really should have come from the factory by default. A more seasoned truck owner could probably tell us why that's not the case.
My 51 F1 doesn't have'em, why should my 21 F150? I'm not sure how this new truck will be 149 better than my old one...
Just ordered my liners, today.
After your liners are installed you might want to use this product to keep them looking good.
