Just put a test light on each one with vehicle in reverse.Need to tap into reverse light wire. Anyone know what color it is on a 2025?
There isn’t just one reverse light, there are 3 or 4 meant to light up based on the load in the truck, or all of them when you are in reverse. So it sends a can bus message which determines how many lights to turn on.What’s this mean? How can you not have a hot reverse wire in the tail light?
Interesting. I’ve got a Morimoto license plate bracket boost bar. I wouldn’t think it would matter which one I tap into.There isn’t just one reverse light, there are 3 or 4 meant to light up based on the load in the truck, or all of them when you are in reverse. So it sends a can bus message which determines how many lights to turn on.
This is why you have to be careful purchasing aftermarket taillights and wiring harnesses. Lightbars come in a “with scales” version.
Yes. The gauge difference may be an issue for the connector, and I didn’t think about that. May just tap into the tail light instead.The yellow reverse wire in the 7 pin trailer connector/harness should be a plain old 12V hot line regardless of if you have the fancy weight scale tail lights. That seems like the easiest thing to tie into for your boost bar. Yellow for reverse hot, white for ground (verify with a multimeter). With that said, the trailer connection wires are likely much heavier gauge than the tail lights and your boost bar wires, especially the white. Consider that when doing your splice you may need step down crimp connectors.
Thanks. I got it, and tapped into those two wires. Then I tested the pigtail and it was hot. Then plugged into the Morimoto led bracket, and nothing. It must be faulty?Use the clamp on the test lamp that you would normally clamp to chassis and clamp it to the black/yellow GND wire. Then the test probe to the hot green/brown. A multimeter would be better but that should work, especially since a quick google search I just did confirmed your color findings.
Seriously? A 9v?touch the morimoto leads across a 9V battery and see if it lights just to rule out your wiring job
I thought about hitting the leads on the battery but was afraid I might short something out.9V should work though it might be dimmer than expected , 12v car or power tool battery would work great. whatever you have that can energize it to the 9-16V it’s rated for just to see if it works
