White Knuckle Rock Sliders Installed
Charky
Arkansas
These are well made and heavy, didn't weigh them ahead of time, but probably around 120lbs per side. Started to install them myself along with my son-in-law but wimped out and had a shop install them.
Those look great! Does the lower part of the mount ,where the bottom bolt goes through, hang below the slider? Just wondering if it’s a catch point? Those sure do look perfect though!
The slider is higher than the bottom of the frame and the bolt/bracket is a little below the frame. The transmission, transfer case and gas tank skid plates are even with or slightly lower than these bolt/brackets in those locations of the frame. The brackets are each a 1/2" thick steel with rounded corners so I'm not concerned.
Thanks for the info!
I'm not sure how I missed this... oh yeah, '23 has been brutal.
Looks great, man! Those things are absolutely solid! I've put them on 3 trucks and have never had an issue.
