Thanks for the input and I agree. What inhaled most on the 4Runner what the nose dive after all the weight. Hoping to avoid that this time around.The only real issue is that is gets expensive fast, especially if trying to change the ride height. I'm leaving mine alone until there are better Tremor specific coil-over options regarding spring selection and a setup that doesn't reduce travel. I'm coming from Land Cruisers and 4Runners myself, and adding a winch to my vehicle was what really started making me dislike driving it on the road. I went about 50% overland on a GX460 with a winch, bumper, 2" lift, etc. The Dobinson's IMS suspension alone was awesome, but adding the bumper, winch, AGM battery, and compressor turned it into a pig. My Tremor is staying OEM+ and I'll probably add a compressor in the bed.
Even adding just BudBuilt DOM Steel sliders to my LC200 made a noticeable dent on handling, and they were 77lbs a piece, low on the body and spread out evenly front to rear.
I did the hidden winch on my 2022 Tremor last year. I used the Swarfworks mount. They had to make a different plate for it to work with the Tremor, but they got it to me quickly. You might want to double-check that when you order. I had to also do an intercooler relocation/replacement because I have the Ecoboost. I used the Full Race motorsports intercooler powder-coated black, and a turbo smart BOV. I also elected to use a Warn Zeon 10-S Platinum winch. I could not find a Warn Zeon 12-S Platinum anywhere and they were all on backorder with no ETA when I was looking. I decided to go ahead and pay the premium price for the Warn Zeon Platinum because of the wireless remote that also controls the clutch. It does not have the regular manual clutch. I think it would be a bit more challenging using other winches in the hidden mount. So it was quite an expensive endeavor because of the intercooler relocation and also going with a top-end winch. I have been very happy with the final outcome. There is an old thread about winches somewhere were I posted some before. But here are a couple of pics.I'm also thinking of the swarfworks hidden winch and will be interested in hearing all the modifications you make. Do you have the 6 or 8 cylinder engine?
Love those extra fog lights you have there. Mind if I ask about the mounting brackets and brand of lights? Thank you. - RobI did the hidden winch on my 2022 Tremor last year. I used the Swarfworks mount. They had to make a different plate for it to work with the Tremor, but they got it to me quickly. You might want to double-check that when you order. I had to also do an intercooler relocation/replacement because I have the Ecoboost. I used the Full Race motorsports intercooler powder-coated black, and a turbo smart BOV. I also elected to use a Warn Zeon 10-S Platinum winch. I could not find a Warn Zeon 12-S Platinum anywhere and they were all on backorder with no ETA when I was looking. I decided to go ahead and pay the premium price for the Warn Zeon Platinum because of the wireless remote that also controls the clutch. It does not have the regular manual clutch. I think it would be a bit more challenging using other winches in the hidden mount. So it was quite an expensive endeavor because of the intercooler relocation and also going with a top-end winch. I have been very happy with the final outcome. There is an old thread about winches somewhere were I posted some before. But here are a couple of pics.
Did you do anything suspension wise?I too did the Swarfworks winch mount. I did the Cobb intercooler. I used the Warn Zeon 10-S Platinum winch. I am happy with the whole setup.
I installed the SwarfWorks on my 5.0 f150 tremor, their winch mount is great, very well built and they are also very responsive if you have questions and so.Hey all,
About to hit send on the swarfworks but wanted to clarify whether the additional weight would require a suspension adjustment. Coming from a 4Runner to this.
The suspension needs to be replaced on these trucks at 50K-100K?I installed the SwarfWorks on my 5.0 f150 tremor, their winch mount is great, very well built and they are also very responsive if you have questions and so.
In my case I did the warn Zeon 12s platinum, with weights around 80 pounds, the winch mount weights around 60 pounds, totaling 140 pounds, not sure if the tremor suspension has anything special in it but seemed to handled the weight addition really well, I'm still on the lookout for any weird behavior, if anything points me to the need of a new suspension will certainly consider it, still, keep 2 things in mind, some factory made suspensions are very well made and might be better than the replacement, soil you are replacing make sure your replacement is actually better than your current one, the other thing is, suspension needs to be replaced on these trucks at 50k-100k miles so doing some research and having the best replacement in mind will be useful on the long run, I personally like Fox suspensions but Halo lifts seems to have good quality as well.
Is something I read here:The suspension needs to be replaced on these trucks at 50K-100K?
I’ve never heard of this before on any F150 trim.
