Wind/air noise
AZTB
Arizona
2022 F-150 Tremor
2014 Cayenne Diesel
My Tremor is my first truck, so maybe I'm just a truck newbie and unfamiliar with what I suppose are relatively worse aerodynamics, but my truck is making what seems like an extreme amount of wind noise at the driver's window. At least extremely noticeable vs. previous SUVs, like volume up to 9 or 10 to minimize it. Is this consistent with anyone else? Can't tell if it's normal/to-be-expected or some kind of bad seal in the window.
Make sure your windows are all the way up. I know that seems obvious, but mine was just slightly down when I got it. Not enough to see it, but enough that I heard it. After I found that the truck is very quiet.
that's certainly what it sounds like, but unfortunately not it
Weather stripping issue?
I don't see anything obvious but I'm guessing that's what it has to be or the window isn't going all the way up behind it.
I guarantee it’s your mirror. Fold it and I bet the wind noise goes away. The seal in the hinge is junk, there gaps that create the air noise.
