Winter Tire Pressure
FeeltheTremor
Ontario
2023 Tremor
I just installed a set of Studded Firestone Winterforce LT tires. I'm wondering what pressure people are running their winters at?
Should be fun to play in the snow having the Torsen Front Diff.
I thought I was running standard pressure on the Baja Boss A/T tires… not enough actual snow on the ground to air down. But looks like they’re at 27 psi.
27 oh that's lower then I thought. The stupid installers had my right front at 47 left at 37 rears at 35 and 32?? I guess they don't have a gauge. No wonder the truck was all over the hwy. We got 30cm last night. I put them all at 32psi for now but have read lots of different opinions from 30-40psi.
Still on stock generals. Cold weather has them at 33-34psi depending if the temp is below or above 0c.
When you find the right pressure for how you use your truck you'll find the traction is better, the ride is better and it tracks properly on the highway. Not to mention the tires wear poorly. Too much or too little and all those things go out of whack.
That's exacly why I was hoping to get some input. Seem pretty good at 32 cold goes up go around 35 hot. Maybe I'll contact firestone for their input. Also wondering my my spedo if off with the same size tires. I'm not impressed.
